How to develop of lumbar spine ligament
    • muhd.safwan78
      Static structural analysis on lumbar spine
      What easiest way to develop the ligament for human spine L4 L5? using Line bodies beams covert it to truss or links. or using spring element as ligament. or have another way to develop the ligament.
      if anyone have done this before, can share how you do it.
    • Dennis Chen
      Hello, there are actually a lot of papers out there that explained how this is done so do some quick searches.    I've used a series of discrete elements (mat_nonlinear_elastic_discrete_beam) in one of my project with the author of this dissertation:  https://biomed.drexel.edu/implantcenter/CV-Dissertations-Thesis/steven-rundell-dissertation.pdf
      hope this helps you and Steve is Awesome!
    • JohnSoliz99
      @Geometry Dash Lite The easiest and most common way to develop a ligament model is to use spring elements, because biological ligaments behave much like a nonlinear spring that can stretch and absorb loads elastically. Spring elements allow researchers to easily assign stiffness and deformation parameters that match real biological data, and are easy to integrate into finite element models.
