How to Determine Resonant Frequency using Harmonic Response
    • narayan.tosur
      I am working on a project where i need to determine the Resonant Frequency of an automotive infotainment display.
      Can you please explain the methodology on how to determine the Resonant frequency using Harmonic Response?.
      Narayan T
    • Akshay Maniyar
      Hi Narayan,
      You can perform modal analyis and then connect the harmonic analysis system to it. So that, you can check natural frequencies first and then perform harmonic analysis using MSUP method. I have attached a course link which can check for more details.
      Topics in Harmonic Response Analysis
      Thanks,
      Akshay Maniyar
  • The topic ‘How to Determine Resonant Frequency using Harmonic Response’ is closed to new replies.
