September 12, 2024 at 2:15 am
885135672
SubscriberWhat are the damage initiation and evolution criteria used by ANSYS to solve interface failure problems, and is it possible to view the failure results directly. I can't find it from the ANSYS help file.The official website case also does not give an explanation and lacks the corresponding theoretical explanation. Not as easy to understand as abaqus in these areas.
September 16, 2024 at 7:38 pm
John Doyle
Ansys EmployeeWith regards to simulating debonding or delamination via cohesive zone modeling (CZM) there is some overlap between the use of INTER20x elements and CONTA17x elements.
INTER20x elements require shared topology between the two debonding bodies, while contact allows for different mesh densities between the two bodies.
The CZM damage initiation and evolution criteria for both INTER20x and CONTA17x are described in Section 4.11 of the MAPDL Theory Manual.
The CZM Debonding Parameter (DPARAM) and Fracture Energies (DENERI and DENERII) can be post processed via ETABLE command (ETABLE,lab,nmisc, ).
Please refer to the CONTA17x element Documentation for the appropriate NMISC values.
3467
1057
1051
929
896
