July 2, 2019 at 3:16 pm
July 3, 2019 at 4:07 pm
Forum ModeratorCan you export an stl of the surface? One issue is whether the student licence can deal with the number of facets.Â
July 3, 2019 at 4:12 pm
July 3, 2019 at 10:07 pm
peteroznewman
SubscriberUse SpaceClaim to open the STL file. It will be a facet body and there are no limits on how many facets. If you are on a full license (not the Student license) you can convert the STL to a Solid by simply RMB on the facet body and a menu pops up. The problem for the Student license is that each facet becomes a face and there is a 300 face limit on the Student license.
July 8, 2019 at 8:10 pm
July 9, 2019 at 10:02 am
Forum ModeratorIf you check the spacing in Mech is it 10m exactly? 253mm suggests it's converted to inches somehow but retained metric dimensions?Â
July 9, 2019 at 7:49 pm
July 9, 2019 at 11:24 pm
peteroznewman
SubscriberIf you import an STL file into SpaceClaim, you can RMB on the Facet Body and Convert to Solid. Then you can use the Design tool to Scale the solid body up to the correct dimension. Since it is a solid, you can subtract it from another solid.
July 10, 2019 at 6:06 pm
jil260
SubscriberWhat's RMB stand for? I selected all facets and covert to solid(merge facets).
July 10, 2019 at 6:08 pm
peteroznewman
SubscriberRight Mouse Button (RMB) pops up the menu to Convert to Solid.
July 10, 2019 at 8:45 pm
jil260
SubscriberThank both of you! Problem solved.
- The topic ‘How to derive the geometry from fluid-structure interaction results’ is closed to new replies.
5654
1885
1404
1303
