April 8, 2024 at 8:59 am
315914335
SubscriberI hope to define the Pre-Exponential Factor of a chemical reaction as a function of the current substance concentration. Therefore, I need to get the mass concentration of a certain substance I need from fluent, and then define the pre-exponential factor through the functional relationship. Hope to get detailed answers and examples.
April 8, 2024 at 10:56 am
Forum ModeratorThere doesn't look to be a hook in that panel for that, I know it's been asked before so check (search) on here.
April 8, 2024 at 11:05 am
315914335
SubscriberMaybe UDF is a method. Can you provide relevant examples? I couldn’t find any relevant useful answers before.
April 8, 2024 at 11:40 am
Forum ModeratorI can only point you at the UDF documentation; you may find you need to write the whole chemistry model. I did raise an enhancement request last time this was requested, but I can't share any updates on that.
April 8, 2024 at 11:43 am
April 8, 2024 at 1:48 pm
Forum ModeratorCorrect. Hence you may need to do a lot more coding at present.
April 8, 2024 at 1:53 pm
315914335
SubscriberHello, can you provide me an example of the code. Do you need to define the entire chemical rate or just Pre-Exponential Factor?
April 8, 2024 at 2:12 pm
Forum ModeratorDouble check the Fluent theory to make sure it's not doing what you need, but otherwise you may find DEFINE_VR_RATE or DEFINE_NET_REACTION_RATE to be of use. There will be examples using both macros in the UDF manual.
April 8, 2024 at 2:14 pm
315914335
SubscriberThank you for your reply
- The topic ‘How to defined Pre-Exponential Factor as function in Fluent?’ is closed to new replies.
