TAGGED: coupled-simulation, ekill-elements, mechanical-apdl
October 16, 2021 at 3:43 pm
k_ujjwal
SubscriberHI,
How to define thermal conductivity K(T(t)), which is a function of temperature 'T' at current simulation time 't' in APDL? Also, how to set the thermal conductivity of killed elements to negligible value?
I know, one way of doing it is by manually filling the table with temperature value and corresponding thermal conductivity. Is there a way of doing it automatically, where based on the current temperature value the thermal conductivity changes?
 I am trying to solve coupled problem (sturctural+thermal) in APDL. When plotting temp vs time plot in time-history postprocessor, the node shows a rise in temperature at the time when it is in killed state. I tried to further reduce the thermal conductivity value to 1e-30 by using 'ESTIF' command, but it's not working.
October 26, 2021 at 6:23 pmdlooman
Ansys EmployeeThe MPTEMP and MPDATA commands can be used to specify a temperature dependent thermal conductivity. ESTIF can be used to lower the thermal conductivity of dead elements. I would never specify such a small number as 1e-30 though. It could produce ill-conditioning. 1e-12 should be small enough. The temperature change in the dead elements may not be due to thermal conductivity. It may be necessary to constrain the nodes of dead elements to a temperature. (Only nodes that aren't shared with live elements.)
Viewing 1 reply thread- The topic ‘How to define thermal conductivity K(T(t)), which is a function of temperature ‘T(time)’ in APDL?’ is closed to new replies.
