March 27, 2021 at 6:31 pm
morlor
SubscriberI'm trying to replicate the condition of model that have both a Hinge and a roller support, I'm having issues trying to find the equivalent in Ansys. I'm attaching both the model I want to emulate and the model I'm doing in Ansys thank you so much
March 27, 2021 at 9:42 pmpeteroznewman
SubscribernThe equivalent in ANSYS is Remote Displacement. It can be a roller or a hinge depending on which DOF you leave free. If all displacements are set to zero and two of the three rotations are set to zero, that will be a hinge around the one axis that had the rotation left Free.nIf one displacement is left Free, that is a roller.nA Remote Displacement can have a Behavior or Rigid or Deformable. If you want the section to remain circular, then you would choose Rigid.nMarch 27, 2021 at 11:48 pmmorlor
Subscriberpeteroznewman Thank you so much for answering, did I choose the right axis in the Remote Displaments according to the axis on the model? , I'm new to this kinda of software n
n
March 28, 2021 at 12:22 ampeteroznewman
SubscribernRoller wants to have Y displacement Free. X and Z displacement set to 0.0 The roller wants Rotation X Free, The other two rotations set to 0.0nHinge wants all displacement set to 0.0 The hinge wants Rotation X Free, The other two rotations set to 0.0nMarch 28, 2021 at 1:27 ammorlor
Subscriberpeteroznewman thank you I'm gonna change the values and check how the model behaves nMarch 26, 2023 at 2:11 pmSubhankar Chakraborty
SubscriberThank You for your guidance .
Viewing 5 reply threads- The topic ‘how to define roller and hinge support on Ansys ?’ is closed to new replies.
6269
