October 13, 2018 at 3:26 pm
aliBaratian
Subscriberhi every body
i have two concentric beams as in pic below:
the left side is fixed for both. the inner longer beam is forced down and i have defined the beams to be in "no separation" contact.
the problem is the inner beam penetrates and gets out of the tubular beam as in pic below !
can any one help me with this?
thanks in advanceÂ
October 13, 2018 at 4:17 pm
peteroznewman
SubscriberInsert a Contact Tool into the Connections folder and Generate Initial Contact Results. Look to see if the contact is closed.
If not, edit the Pinball Radius on the contact and make it larger.
October 13, 2018 at 4:20 pm
Sandeep Medikonda
Ansys EmployeeBeam to beam contact underwent a major upgrade in 19.1.Â
Please post snapshots of the contact details you are using?
Sandeep
Best Practices to post on the Student Community
- The topic ‘how to define no separation contact between beams?’ is closed to new replies.
Ansys Innovation Space
1188
1076
1063
952
