How to define multilinear stress-strain curve in ansys APDL
    • indra1994
      I am trying to define a multilinear stress-strain curve for each SOLID185 element in my ANSYS model. The stress-strain relationship is shown below. So far I have no idea how to define this multilinear relationship in ANSYS APDL 2019 R2. I tried to model it as Multilinear Isotropic Hardening but ANSYS throws error as the tangent slope can not be less than zero.
      Can Anyone please help me with this?
    • John Doyle
      KINH and MISO plasticity models do not support negative slopes as you have reported.
      Make sure that your data input represents true-stress vs true strain.  The slope might be positive after all.
      If that is not the issue, there is another option.  TB,NLISO,, will support a negative slope beyond yielding.
      Keep in mind, the negative slope implies instability.  Static analysis under a force based load will likely not converge if all the elements in the primary load path go totally plastic.
      Hope this helps.
    • indra1994
      Thanks for your reply, It really helps.
  • The topic ‘How to define multilinear stress-strain curve in ansys APDL’ is closed to new replies.
