May 15, 2024 at 6:34 am
yahyabalouchi
SubscriberI'm reaching out with a query regarding the definition and monitoring of relative parameters within the ANSYS software suite.
Specifically, I'm interested in understanding how to define and effectively monitor parameters such as P/P0, where P0 denotes the initial pressure. Could you kindly provide guidance or resources that elucidate the process of setting up and tracking such relative parameters within ANSYS?
Any documentation, tutorials, or insights you could offer on this matter would be immensely helpful for our ongoing projects.
Thank you very much for your assistance and support.
May 17, 2024 at 1:24 pm
Federico
Ansys EmployeeI would suggest using Named Expressions for this: 5.3. Creating and Using Expressions (ansys.com)
May 17, 2024 at 1:28 pm
Federico
Ansys EmployeeYou can then use Report Definitions to monitor your expression quantities: 40.2. Monitoring and Reporting Solution Data (ansys.com)
- The topic ‘How to define and monitor relative parameters in fluent?’ is closed to new replies.
5719
