how to define a rigid plane in Ansys Mechanical APDL?
    • chenyuanming
      Hi there,
      I want to simulate a compression test of a structure, I want to use a rigid plane to compress the structure. but how to define the rigid plane quickly with apdl or GUI operations?
      Thank you!
    • chenyuanming
      like the rigid body in the picture
    • mrife
      Please see the following help section: Ansys Help -> Mechanical APDL -> Contact Technology Guide -> Chapter 2 GUI Aids for Contact Analysis. Specifically the section on the Contact Wizard. When defining a contact pair the Target side has an option of being flexible or rigid. If rigid there is also an option to include a pilot node. The moving and fixed rigid bodies can be modeled as surfaces or volumes. Then the appropriate surface used to define the target side.
      Have fun Mike
    • chenqingsen
      Hello´╝îdo you know how to define rigid-flexible contact using APDL ?
  • The topic ‘how to define a rigid plane in Ansys Mechanical APDL?’ is closed to new replies.
