October 2, 2021 at 5:18 am
Rohan1
SubscriberHello, I have a line bodies extracted in ansys spaceclaim, but I cannot define contact between a vertex and edge. How to generate contact between a vertex and edge, what other options can be considered in such case and what settings should be given?
October 5, 2021 at 12:35 pmVinayak Vipradas
Ansys Employee,
You cannot generate a contact between a vertex and an edge. Instead you can use Fixed Joint, which is appropriate for this model. You can refer to these links for detailed overview of the types of contact.
Supported Contact Types (ansys.com)
Connection Group (ansys.com)
Thanks,
Vinayak.
September 6, 2023 at 2:58 pmGwang Na
SubscriberIn the 'advanced' group, select 'Beams' in Formolation item. Then specifiy radiou value to capture the target edge line. Â
Viewing 2 reply threads- The topic ‘How to define a contact/ joint for a vertex edge pair’ is closed to new replies.
5729
