How to deal with “Unable to view geometry, Unable to get model”
    • hwmachine
      While I was using the Workbench, I found a problem that has never occurred before: "Unable to view geometry, Unable to get model". This is the 1st time I met this problem, the screenshot is sent as an attachment for your reference.
      This problem occurs in "Steady Structural" but the "Steady-State Thermal" can run normally.
      Thanks in advance!
    • hwmachine
      If I use the coupling of the Thermal and Structural model, the software will also crush but with another error.
    • tdevlieger
      I get a similar error:
      System.InvalidOperationException: Unable to view geometry. Unable to get model.
      at Ansys.Addins.Infrastructure.Remoting.RemotingApiHelper.FatalApiMethodInvalidOperationException(String message, RemotingApiMethod callback)
      at Ansys.Simulation.Core.Commands.EditModel.ViewModel(IFullContext context, DataContainerReference modelContainer)
      at Ansys.Simulation.Core.Commands.EditModel.ExecuteCommand(IFullContext context)
      at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
      at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
      at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
      at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
      --- Ansys.Core.Commands.CommandFailedException: Unable to view geometry. Unable to get model.
      CommandName: Mechanical.EditModel(Container="Model")
      at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
      at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
      at Ansys.Simulation.Core.Commands.EditModel.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive, Boolean Hidden, Boolean StartAsReadOnly)
      at Ansys.Simulation.GUI.EditModel.InvokeCommand(GuiOperationContext context, DataContainerReference dcr)
      at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation(GuiOperationContext context, IGuiOperation guiOperation, DataContainerReference dcr)
      at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
      at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
      If you can help me out, that would be great.
      Sincerely
    • Harish B
      I'm also facing the same issue. It would be great if someone helps me.
    • pdlagrosas
      same problem here
Viewing 4 reply threads
  • The topic ‘How to deal with “Unable to view geometry, Unable to get model”’ is closed to new replies.
