July 24, 2021 at 9:02 am
jaiswal1706
SubscriberProblems I am facing:
1. Reverse flow at the outlet (I tried extending the domain, but to no avail.)
2. Maximum temperature/ pressure limited in....
3. Solution not converging, particularly the residual for continuity. Other residuals also take a lot of iterations for converging
Kindly find the details of the set-up here:
1. Steady State, Density-based, Axis-symmetric
2. Spalart Allmaras Turbulence Model with energy eqn on
3. Air modeled as ideal gas with Sutherland model of viscosity
4. BCs: (i) Pressure inlet, Gauge Total Pressure = (NPR*101325 - 101325) ; Supersonic/ initial Gauge Pressure = 5 Pa less than the total pressure; Total Temperature = 300 K.
(ii) Pressure outlet, Gauge Pressure = 0 Pa, Total Temperature = 300 K
(iii) Temperature of 300 K applied at walls
(iv) Operating Pressure = 101325 Pa
Details regarding mesh:
Structured mesh with 2,52,958 cells.
Avg. element quality = 0.79571, Min. element quality = 0.28747
Avg. skewness = 1.2058e-002, Max skewness = 0.35188
Avg. aspect ratio = 2.0994, Max aspect ratio = 6.7975
Avg. orthogonality = 0.99705, Min orthogonality = 0.85175
Kindly help me on this. I am also attaching the pictures of domain and mesh being used for the simulation.
July 26, 2021 at 1:41 pmRob
Forum ModeratorPlease add some images of the results. Note, the jump in cell size won't help but the problem may lie in the mesh resolution or initial conditions.
Viewing 1 reply thread- The topic ‘How to deal with non-convergence while simulating compressible flow inside an aerospike nozzle?’ is closed to new replies.
5664
1890
1419
1304
