September 19, 2022 at 9:51 am
cez198229
SubscriberI am trying to develop a Hexa mesh in a flow domain with a cylinder in a scour hole. The flow domain is shown below.
The bottom surface and the cylinder surface are treated as walls, and hence the inflation layers are provided around them.
The developed mesh contains some negative quality elements at the intersection of the cylinder with the bottom surface.Â
How can I remove those cells from the mesh?
I tried pre-mesh smoothing but was unable to remove them.Â
Please find the figures below
1. Flow domain
2. cylinder and bottom surface
3. Blocking
4. Mesh section
5. Negative quality elements
September 20, 2022 at 1:27 pm
V.P
Ansys EmployeeHello
I think if you can give an Ogrid split to the cylinder, it might help increase the quality of cells at the sides of the cylinder.Â
For more information on creating Ogrid Split, please refer this video:
Also, you can refer the documentation here: Ogrid Block (ansys.com)
If you are not able to access the link, please refer to this forum discussion: /forum/forums/topic/using-help-with-links/#latest
September 21, 2022 at 5:42 am
- The topic ‘How to deal with negative quality mesh elements in ICEM CFD mesh?’ is closed to new replies.
5654
1885
1404
1303
