January 7, 2025 at 2:54 pm
chandrunresearch
SubscriberI want to create parallel and angular misalignment in the coupling in a rotor-bearing system. Is there any possibility to create in AnsysÂ
January 8, 2025 at 3:56 pm
dlooman
Ansys EmployeeNo, there's no feature for that. The misalignment needs to created in the geometry. Also, WB/Mechanical only supports a single rotational velocity. You can't scope rotational velocity to a body. Â
January 19, 2025 at 12:34 am
chandrunresearch
SubscriberThanks a lot Mr. dlooman.
January 19, 2025 at 12:40 am
chandrunresearch
SubscriberSuppose if we create parallel or angular misalignment at coupling in geometry itself, then ansys will exactly solve for the results considering misalignment. Whether Ansys WB or APDL, which will be suitable for these types of problems. Â
January 20, 2025 at 8:08 pm
dlooman
Ansys EmployeeYou'll need APDL to input cmomega for multiple rotors. Mechanical only supports a single angular velocity on all bodies.
