How to create sliced plots to visualize changes in a variable over a distance using Ansys Workbench?
    • ravichsj
      Hello Ansys users,
                      I am working on a project in which is in correlation with acoustic imaging using Ansys Workbench. I applied a planar acoustic pressure field on one side of the model and obtained the results for total deformation. I want to create a sliced plot to visualize the changes of the deformation over a distance. I have observed that this is possible using COMSOL Multiphysics software. I want to obtain the same in Ansys Workbench. I have attached the model for your reference. I have also attached the sliced plot result of some other model which was done by COMSOL for further understanding. Thanks in advance!
    • Hui Liu
      creating a "section plane" lets you look at the result at certain cross section. does that work for you?
    • ravichsj
      That should suffice. Thanks a lot!!
  • The topic ‘How to create sliced plots to visualize changes in a variable over a distance using Ansys Workbench?’ is closed to new replies.
