May 13, 2019 at 8:42 am
May 13, 2019 at 9:55 am
jj77
SubscriberIf you define a connection of bearing type in ANSYS workbench, then there is an option to have that face where the bearing is on as rigid.
See the tutorial below:
https://www.youtube.com/watch?v=_orD6Tjwb_A
May 13, 2019 at 10:03 am
moeenkhurram
SubscriberHi, thank you for the reply, in my model , I replcaed rollers with non linear springs , roller characterisitc is shown by springs . I am not sure I should apply bearing type connections.
Each roller is alreday replcaed by 5 springs
May 13, 2019 at 10:05 am
jj77
SubscriberIf you want springs then in the tutorial above, and at the end, they apply spring connections (with rigid behaviour at the connecting face) - hope this helps
May 13, 2019 at 10:11 am
moeenkhurram
Subscriberyes I checked whole tutorial , there was option for ridig connection , but it is only available in remote connection mode not in direct connection mode , I have total 700 springs in model which cannot be generated(cannot use object generator) by remort connection option.
I made one spring by direct attachment then used 'object generator' to multiply it .
May 13, 2019 at 10:18 am
jj77
SubscriberDo not know that one, not sure. Perhaps someone else has some ideas
May 13, 2019 at 11:27 am
jj77
SubscriberAlternatively if you do not care about these areas which you obviously don't since you want them to be rigid, create surface bodies on these areas (red patches) and set the Young's Modulus for them say 10 times higher than steel (use say a couple of mm thickness).
May 13, 2019 at 9:05 pm
May 13, 2019 at 9:40 pm
jj77
SubscriberThanks for that but I am not looking for any info, if you though could see the original post and see if you can help that would be appreciated for sure by
moeenkhurram -
May 15, 2019 at 8:04 pm
- The topic ‘How to create rigid region for spring connection in Ansys mechanical ? in meshing or geometery’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4167
1487
1338
1172
