August 3, 2020 at 2:59 am
Keyur Kanade
Ansys EmployeeHow to create point at specific coordinates using SpaceClaim? -
August 3, 2020 at 3:20 am
Karthik Remella
AdministratorCreate the point at origin and then with the Move tool use the option Enter XYZ coordinates and manually enter the coordinates. -
August 3, 2020 at 9:58 am
Keyur Kanade
Ansys EmployeeBut I have multiple points to be created and that could be tedious to create each point and move it to required location. -
August 3, 2020 at 10:05 am
Karthik Remella
AdministratorWrite a text file using the commands show below and then open it with Assembly -> File.
The file should follow this format:
3d=True
polyline=False
1 0 0
1 0 1
1 1 0
1 1 1
The coordinates are defined as (Z, X, Y). Use as many lines as the number of points needed. Make sure that the units used are consistent. -
August 3, 2020 at 10:31 am
Keyur Kanade
Ansys EmployeeHow can I create curves passing through the points? -
August 3, 2020 at 10:48 am
Karthik Remella
AdministratorPlease visit for more info:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/SpaceClaim/v195/en/Default.htm%23Importing_and_exporting.htm%3FTocPath%3DFile%2520Operations%7C_____2 -
November 15, 2022 at 5:24 pm
Hasan Ammarul
SubscriberI created the points, but can't connect the points.. Prepare>create
This create tool is not working
How to enable this tool anybody know please?
Viewing 6 reply threads
- The topic ‘How to create point at specific coordinates using SpaceClaim?’ is closed to new replies.
Ansys Innovation Space
1414
1241
1118
1015
