January 27, 2020 at 11:56 am
Pixinot
SubscriberHow is it possible to create pattern for cut material body. The problem is that i can't choose cut material body as geometry for Pattern
January 27, 2020 at 2:20 pm
Forum ModeratorPick the "sides" of the hole and pattern that.Â
January 28, 2020 at 6:42 am
January 28, 2020 at 7:25 am
Pixinot
SubscriberOr another question. How i can make body inside body. When i switch the small box to "Add frozen", "Mechanical" thinks that big box just go through small box without interaction each other. So how to make a small box with one material inside the big box with another material and make a contact with them
January 28, 2020 at 9:48 am
Forum ModeratorYou need to split out the geometry. Multi-body parts might do that, but (safer) is to slice or subtract+retain. Basically, in CAD you just need to show people where things are, in simulation we need to actually represent the bodies and their relationships.Â
Re the first question, have a look at pattern, Named Selections and subtract. It's possible, but you need to do it in the right order.Â
- The topic ‘How to create pattern for cut material body in DesignModeler?’ is closed to new replies.
4678
1565
1386
1242
