April 26, 2018 at 5:27 am
deepmech.maurya
Subscriberhello sir,
         i want link180 element for my analyses as this can work in tension only.
i want to design the ligaments which works in tension only and no effect on compression.Â
In mechanical apdl file i learned that :
et, matid,link180 ! element typeÂ
secdata,tenskey,1! it is the command to control the link either work in tension(1) or in compreesion(2)
but i didnot succeeded.
Please help
regardsÂ
Deepak
April 27, 2018 at 11:42 am
deepmech.maurya
Subscriberhello Peter sirÂ
             I solved the problem with link180 element but i have doubt in result, please check it.
file attachedÂ
it is recognising element link180Â but showing value of deformation of link in compression,but how to get stresses on link in ansys.
thanks waiting for response
April 27, 2018 at 12:06 pm
peteroznewman
SubscriberDownloading now and will check it out.
April 27, 2018 at 2:14 pm
sk_cheah
SubscriberI changed a few things...
- seccontrol,,1Â (not seccontrol,tenskey,1)
- Model is not well constrained. Joint added to allow only for rotation.Â
- To avoid small pivot problems, density and gravity was added so the relaxed links won't be flapping in the wind
- Analysis settings: Large deflection: On & Nodal Forces: Yes
I attached the tweaked model.Â
Kind regards,
Jason
April 27, 2018 at 3:04 pm
deepmech.maurya
Subscriberhello Jason,
          thankyou Now going to review the model sent by you.
regards
Deepak Maurya
April 27, 2018 at 3:36 pm
deepmech.maurya
Subscriber hello Jason sir,
             i have some doubt:
1) you replaced moment by joint moment,Why?
joint moment is wrt ground in particular direction similar to moment also (acted in particular direction)
2) direction of gravity is along the side of body in Zdirection (i think by mistake universal direction chossen)
My main aim is to use this link as ligament of human body for my analyses, ANY suggestion
regards
DeepakÂ
April 27, 2018 at 5:23 pm
sk_cheah
SubscriberHi Deepak,
- With an applied moment, the body will 'fly' until the string catches it, then do a few acrobatic somersault. It's tough for Ansys to converge on the flight path. The joint constrains the body to have a 1DOF that is controlled by LINK180.Â
- Imagine the string is in outer space with no gravity. When it is not in tension, it is simply floating around. To avoid this ill defined problem, a small gravitational force is applied. This should not significantly affect the attached body while helping convergence.Â
Kind regards,
Jason
April 29, 2018 at 4:01 pm
peteroznewman
Jason explained this very well. Remember to add a Density property to the materials assigned to the LINK180 so that the gravitational force will have something to pull on!
Kind regards,
Peter
April 29, 2018 at 4:26 pm
deepmech.maurya
SubscriberHello JasonÂ
          one query i have ?
   the model you messaged me is working nice but problem is this when you define Material properties as command in WORKBENCH it is not considering it.
the last model has steel as default material so density was feed previously. I created ligament material properties and didnot provide density in add material but i add density during command it is not accepting it.
RegardsÂ
Deepak
April 29, 2018 at 4:56 pm
peteroznewman
SubscriberHello Deepak,
The reason I posted above is because I added a Modal analysis to your New Beginnings file and found that there was no density assigned to the ligaments. I went in and added that in Engineering Data and am running the Modal now to look for loose parts.
Peter
May 1, 2018 at 4:40 am
deepmech.maurya
SubscriberHello Peter sirÂ
           i also performed the modal analyses yesterday for five vertebrae without ligaments and message the file to you but its fail as size cross 15 GB of my gmail. I just want to tell that if you see the modal analyses of first five modes it shows the five physiological motion of human body 1)compression
        2) forward bending
        3) backward bending
4) lateral bending and so on.
i performed for five vertebrae.
thankyou
May 1, 2018 at 9:28 am
peteroznewman
When I tried to run the Modal analysis with the ligaments, there were no results. I'm glad you got a reasonable result.
Peter
- The topic ‘how to create link180 element in TENSION in ansys workbench?’ is closed to new replies.
6239
