July 10, 2024 at 12:31 pm
Xime54
SubscriberHi every one,Â
I have to run calculation in radiometrics units, but sometimes I have to get restults with ponderation curves (ex: V(l) for visual units). I want to put filters in front of my sensors, so I get the restults I want.Â
I have data of ponderation curves in "*.spectrum" files, does any one know how I put a simple surface with this property to simulate my filter?
Thanks a lot.
Maxime
July 15, 2024 at 7:58 am
Thomas Martineau
Ansys EmployeeHello,
Can you try with the advanced scattering surface editor, then in Tools -> Autofill, you can select a spectrum and in select specular transmission.
You can then use the generated file on a surface.Â
Thanks
Thomas
July 16, 2024 at 8:13 am
Xime54
SubscriberHi Thomas,Â
Thanks for your answer, it works fine.
Maxime
- The topic ‘how to create a simple light filter’ is closed to new replies.
1307
