January 24, 2019 at 1:31 pm
AndreaGaggi16
SubscriberHi everyone!
I have a cylindric volume cooled down under zero degrees and I want to see what is happening inside the volume over time.
How can I look inside the volume/create a section?
Maybe it is a simple question but I am an ANSYS beginner, I'm sorry.
Thank you!
Andrea -
January 24, 2019 at 3:55 pm
Forum ModeratorCreate an iso surface of mesh (Post processing tab) for a value that's down the middle of the domain. Display contours, vectors or whatever on that surface.
If you read through some of the examples/tutorials attached to the R19 documentation they'll give you more details.Â
January 24, 2019 at 8:59 pm
January 25, 2019 at 6:10 am
Keyur Kanade
Ansys Employeeclick OFF the boundary zone i.e. wall in model tree.Â
you can check following videos.Â
https://www.youtube.com/watch?v=Mv7w2PBkf8M
https://www.youtube.com/watch?v=nUSQxaL4hks
if this helps you, please mark this post as 'is solution' to help others on forum.
January 25, 2019 at 8:05 am
January 25, 2019 at 10:57 am
Forum ModeratorIt's possible you added the wall into the contour plot, it's easily done when learning.Â
- The topic ‘How to create a section for visualization in Fluent’ is closed to new replies.
5159
1836
1387
1249
