June 9, 2020 at 5:30 am
shravan.bharadwaj7
SubscriberI want to create a new material property called as Temperature Coefficient of Resistance. How to do this? -
June 9, 2020 at 5:37 am
sarathmail63
SubscriberTools -> Edit Libraries -> Materials -> Add materialÂ
June 9, 2020 at 6:07 am
shravan.bharadwaj7
SubscriberI don't want to add a new material. But I want to create a new property called Temperature Coefficient of Resistance and add it to a material. Is it possible -
June 29, 2020 at 10:49 am
rtk
Ansys EmployeeHello,
Adding an entirely new material property to the HFSS system material library seems difficult. But one suggestion is that, utilize the already existing material properties to obtain the required ones. For ex. Thermal Conductivity can be related to Thermal Coefficient of Resistance.
July 3, 2020 at 6:57 am
shravan.bharadwaj7
SubscriberThanks
April 21, 2021 at 12:50 pm
David Mercier
Ansys EmployeeYou can manage your in-house mterial data using for example Ansys Granta MI: https://www.ansys.com/products/materials/granta-minUsing this system, give you the opportunity to create your own database based on user-defined template (specific attributes, properties...etc). Create, control and store valuable materials with this flagship materials properties software, which can be fully integrated across CAD, CAE and PLM systems, using workflow tools. Here a white paper about such challenge:nhttps://www.ansys.com/resource-center/white-paper/efficiently-solve-the-materials-data-management-challengen
Viewing 5 reply threads
- The topic ‘How to create a new material property in ansys’ is closed to new replies.
Ansys Innovation Space
- Shape Memory Alloy Deployment
- Correct Material Definition
- Softening Issues in Reinforced Concrete
- Material Designer – Material Assignment
- Error on Material Designer, One or more errors occurred.
- how to use Plastic material property of steel only
- Hydrogen Simulations
- Is there a simple data base of electronic parts, motors, resistors etc.
970
857
599
591
