Preprocessing
Preprocessing
How to create a bounding box just to define boundary layer
    • JorgeP
      Hello dear friends,
      I'm doing a simulation following this tutorial: https://www.youtube.com/watch?v=6xAb9rdZugs&ab_channel=LEAPAustralia
      I've created a bounding box for my domain and for my constant resolution zone. To do the wrapping, I select extract edges, create intersection loops collectively and shrink wrap but only with my domain and surface.
      Now I need to create a bounding box to define my boundary layer limits. My problem is, if I create it and then select Extract Edges create intersection loops and shrink wrap together with the domain and surface, it will create a domain smaller than I need. But if I don't select the boundary layer box it won't appear on my scoped functions for boundary layer.
      Basically what I need is that my boundary layer bounding box appears on the place I show at the following image but without messing my domain geometry.
      If you have good CAD do you need to use the wrapper? The CleanCAD workflow should then be much easier to use. n
  • The topic ‘How to create a bounding box just to define boundary layer’ is closed to new replies.
