June 25, 2021 at 8:26 am
AStumpf
SubscriberIs there a possibility in fluent to create a text file with the information about the used models, setups and the important information of the used grid (cellcount, type of cells)?
Thank you very much :)
Arne
June 25, 2021 at 9:53 amDrAmine
Ansys EmployeeIn 2021R1 you have the simulation Report which provides a good summary and includes result section too.
June 25, 2021 at 11:43 amAStumpf
SubscriberMany Thanks.
Unfortunately, I'm using 2019R3, and if I don't miss anything, that feature ist not available there.
Is there an other option to do something similar in 2019R3?
June 25, 2021 at 12:12 pmDrAmine
Ansys EmployeeNo in that granularity but you can rely on the Fluent Input Summary which does not contain all information, though. Just search after than in the Guide.
June 25, 2021 at 12:43 pmRob
Forum ModeratorThere's the Input Summary under Run Calculation in the ribbon. The output's not as easily read though.
Viewing 4 reply threads- The topic ‘How to creat a setup-outfile in fluent?’ is closed to new replies.
3597
1283
1117
1068
983
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
