August 27, 2019 at 1:28 am
wangwang
SubscriberThanks for reading.
I already know that my project would need user defined command, in other word, APDL in the next step.
Now, my current project is about impacting and I want to achieve a cohesive behavior during the process. I am using Explicit Dynamics analysis component in Workbench. But I find that there is not a embeded cohesive behavior inside of Explicit Dyanmics and I couldn't insert APDL in Explicit Dynamics module.
So, how can I convert my solution in Ansys Mechanical? Because I heard about that Ansys mechanical or Ansys APDL could solve project from a bottom aspect, like you could always select your element type and input user defined command.
Thanks for suggestion.
August 27, 2019 at 1:44 am
Sandeep Medikonda
Ansys EmployeeSee this Discussion.
You cannot use MAPDL commands in the Explicit Dynamics Solver. They both are different solvers.
August 27, 2019 at 5:27 am
wangwang
SubscriberThank you. You are right, I know that I cannot input MAPDL in Explicit Dynamics module, so that's the reason I asked how to transfer my solution data from Explicit Dynamics into Ansys Mechanical APDL, the most classical FEA software from Ansys corporation. Because I know that Ansys Mechanical APDL could use MAPDL commands and also could simulate impingement process. And I could use MAPDL commands in Ansys Mechanical APDL to postprocess my transferred simulation result.
I am not sure did I clearly express my question.Â
- The topic ‘How to convert Workbench/Explicit Dynamics solution in Ansys Mechanical?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3912
1414
1256
1118
1015
