LS Dyna
LS Dyna
How to convert LS-DYNA reslut files(d3plot, binout) to ANSYS result file(rst)?
    • Cheng Xihao
      I used Lsdyna for vibration analysis and imported the response file into Virtual .Lab for noise analysis, but Virtual .Lab only supports rst files. So I need to convert the LSDYNA result file to rst file
    • Zoi Stavrothanasi
      Hello Cheng,
      Please review the following posts:
      /forum/forums/topic/moving-files-from-ls-prepost-to-workbench/
      /forum/forums/topic/how-to-convert-ls-dyna-key-files-and-k-files-to-ansys-workbench/
      Zoi
    • michael.js
      I too am interested in the question. I would like to use an ANSYS extension to post-process results generated using LS-DYNA (d3plot). I wans to import the results into a static structural as if it were an rst file. The links to previous threads relate to converting .k input files into workbench files and are not applicable.
  • The topic ‘How to convert LS-DYNA reslut files(d3plot, binout) to ANSYS result file(rst)?’ is closed to new replies.
