May 4, 2024 at 10:39 am
Jack lion
SubscriberHello, I'm going to do bone modeling. I made facets by fetching 3dm files from Rhino into spaceclaim. I tried two methods to convert complex facets into solid.Â1. Direct conversion from structure tree to solid: I can't analysis afterwards because too many faces are created.Â2. auto fix -> shockwrap (0.1 mm) -> autoskin : stops while proceeding.ÂIs there an appropriate way to convert complex facets into solids? -
May 5, 2024 at 12:55 pm
peteroznewman
SubscriberHere is a Google Search that has links to several sites that describe how to create a 3D mesh from CT scan data.
May 5, 2024 at 2:23 pm
Devendra Badgujar
Forum ModeratorHi Jack,Â
You can refer this Discovery SpaceClaim: Reverse Engineering tutorials for tips on converting the stl to solid. Create geometry from STL in SpaceClaim - Ansys Knowledge
Let me know if this helps.Â
Devendra
- The topic ‘How to convert complex facets to solid?’ is closed to new replies.
1890
1419
1304
