May 18, 2022 at 1:31 pm
pavelxmares
Subscriberhow to convert a faceted hollow body to a solid body?
May 18, 2022 at 2:12 pm
subashni.satish
Forum ModeratorHello Pavel Mareš
Are you using Discovery or SpaceClaim for this?
In both, you can just right click on the Facet body and Convert to solid.Is there any error you are seeing?
May 18, 2022 at 2:23 pm
pavelxmares
SubscriberSubashniÂ
SpaceClaim
this is coming, but it is too big:
To set STL file options
Select STL in the panel on the left.
Set Import options:Units: Choose a system of units.
Import as:
Connected faceted body: Create a lightweight mesh with full connectivity information between facets.
Simple faceted body: Create a lightweight mesh with no connectivity information between facets.
Solid/surface body: Convert STL triangles into full geometry.
Check the Merge faces check box to seamlessly merge one or more faces.
I have faceted body and I want to fill it out
May 18, 2022 at 2:55 pm
pavelxmares
SubscriberPavel MareÅ¡Â
ok, right click on the Facet body and Convert to solid.
Thanks!
May 18, 2022 at 4:14 pm
subashni.satish
Forum ModeratorPavel Mareš
So did the Convert to solid option work? Is the issue resolved?
May 18, 2022 at 4:22 pm
pavelxmares
SubscriberSubashniÂ
Yes, thanks!
- The topic ‘how to convert a faceted hollow body to a solid body?’ is closed to new replies.
