May 2, 2021 at 6:54 pm
k_ujjwal
SubscriberMay 3, 2021 at 1:02 pmkrada
Subscriberif you are using the direct mesh generation process then you can set the node number as per your desired which end up with your desired numbering. See the "ngen" and "egen" command for this purpose.
May 9, 2021 at 7:57 pmViewing 2 reply threads- The topic ‘How to control the assignment of element number (element id) in ANSYS APDL?’ is closed to new replies.
4914
1608
1386
1242
