April 15, 2024 at 2:49 pm
Mark Smith
SubscriberI'm trying to simulate the effects of electrodes in solution on an existing electric field in Maxwell 2d/3d. I have several electrodes with varying impedance to each other and distant parts of the solution. How can I specify this relationship between the boundaries?Â
April 19, 2024 at 3:03 am
HDLI
Ansys EmployeeHello Mark,
   Could you show some images and more informaiton to explain what is varying impendence and distant parts? Thanks
HDLIÂ
April 30, 2024 at 7:37 pm
Mark Smith
SubscriberHi HDLI. Do you have any recommendations, or requests for additional clarification?Â
April 30, 2024 at 10:09 pm
Mark Smith
SubscriberFor example, COMSOL has Lumped Elements and Lumped Ports to solve these issues. Is there a Maxwell equivalent?Â
April 19, 2024 at 6:50 pm
Mark Smith
SubscriberÂ
Say I have a simple dipole simulation, like above. I want to add two more electrodes to the field, say one at (10,50,0) and another at (10,-50,0). Then I want to put a known impedance between them, so I can measure the current through the element and the effect on the field. Alternatively I could put one at (10,50,0) and one at (10,1000,0) and see the effect of a connection to a 'distant' part of the simulation. Maybe a computationally more effective solution would be to set a boundary with a known impedance to a fixed voltage. These seem like trivially obvious applications for Maxwell but I haven't been able to find any examples.Â
April 24, 2024 at 7:04 pm
Mark Smith
SubscriberWhat other information would be useful here? Having external circuit elements that influence the fields seems like a pretty basic task for an electronics simulation package. I know COMSOL can do it, as well.Â
May 1, 2024 at 12:12 am
HDLI
   Could you try to use Maxwell 3D transient A-phi formulation? I think this solver could simulate above and with external circuit. Thanks.
HDLI
- The topic ‘How to connect boundaries with a fixed impedance’ is closed to new replies.
5649
1885
1404
1303
