TAGGED: ansys-hfss, thermal-conductivity, thermal-electric
July 12, 2024 at 11:40 pm
Jalaj Chaturvedi
SubscriberHi,I want to conduct temperature variant EM simulations in HFSS i.e. s parameters of a CPW at various temperatures. I am using a temperature variant material using thermal modifiers. I have also set the object temperature. But sadly I am not able to perform the simulations. Without temperatures, my simulations are working fine btw. Can someone please help me with that ?ÂI researched a llittle and found that ICEpack can predict temperatures. But the thing is, it predicts temperatures inside a material as a result of excitation i.e. how and where the temperatures will vary across the body as a result of excitation.But what I am looking for is excitation at different temperatures, a very wide range at that and then study the results.ÂPlease help -
July 31, 2024 at 7:40 am
Praneeth
Ansys EmployeeHi Jalaj,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Did you go through "Setting the Temperature of Objects" section of the HFSS help document available through the Help menu.
After setting the temperature dependence you need to run a parametric for temperature to see the effect.
Best regards,
Praneeth.
- The topic ‘How to conduct temperature variant EM simulations in HFSS ?’ is closed to new replies.
