How to combine two geometries from two step files in Static Structural
    • Manoj55
      Assume
      I have one .step file and I did analysis
      Now that step file updated in different software and again made new step file
      How to update these modifications in our previous analysis of old file instead of doing new analysis.'
      Please help me to learn this.
      Thank you
      You brought that STEP file into either DesignModeler or SpaceClaim.
      In either case, just bring the new STEP file into the same project into DM or SC.
      In DM it is Import External Geometry File, in SC, on the Assemblies tab, click the File button.
      Now you have two bodies instead of one.  Refresh the Model and open Mechanical.
      In Mechanical, you can select each load and support and change the scope from one body to the other, then suppress the original body.
  • The topic ‘How to combine two geometries from two step files in Static Structural’ is closed to new replies.
