How to combine the result files in Ansys?
    • Van Toan Nguyen
      Hello everyone!
      I have the result files (.dat.gz) when I simulated by Fluent (as shown below).
      The first files from "0000" to "60000' (denoted by time steps) were obtained and then the program was interrupted so I continued another simulation with the data file saved before. After that I had the result files from "60000" to "100000". However When I used CFD-Post processing to get animation, the time steps were loaded only from "00000" to "60000" or from "60000" to "100000". How can I get full time steps?
      Thank you so much!
    • DrAmine
      You might need to adjust the content of the first cas file and add the missing time step specification there. Alternative is to use Ansys EnSight.n
    • Van Toan Nguyen
      Thank you for your reply. How can I adjust the content of the .cas file?n
    • DrAmine
      Editing in Text Editor on your warranty!n
    • DrAmine
      however I recommend that you repeat the run and try to export cdat files: dat files in CFD-Post are not recommended!n
      If you're messing in the case & data files I also recommend taking a copy. That way if it all goes wrong you don't lose any files. The other option is to post-process the first set of data and keep the State file, then run that state file on the second lot of data. n
Viewing 5 reply threads
  • The topic ‘How to combine the result files in Ansys?’ is closed to new replies.
