September 22, 2023 at 5:47 pm
September 25, 2023 at 12:13 pmFedericoAnsys Employee
"Internal" BC type requires to have fluid cell zones on either side of the face.
If this face has 2 different fluid cell zones on either side and they are not conformal, then you will need to create a mesh interface.
- The topic ‘How to change the ‘wall condition’ into a ‘internal condition’ ?’ is closed to new replies.
Ansys Innovation Space
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- CONVERTING STL FILE IN TO SOLID
- Varying ply angle in ACP
- Element type definition – Ansys Workbench
- ANSYS ACP Modelling Issue
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
599
591
555
366
