July 4, 2024 at 5:37 pm
Nurhalim Dwi Putra
SubscriberHello everyone,
I want to display a visualization using the pressure and motion wave contour display in Ansys AQWA HD, using several different photo results, but the max-min value in the legend remains the same in each photo result. How do I set it so that this value can be customized and not automatic? Where do I find it in the menu? Because currently the default menu is locked
Thank You
July 11, 2024 at 9:58 am
Mike Pettit
Ansys EmployeeHello,
I'm afraid there is no way to modify the min/max values in recent versions of Aqwa Workbench. I will try to get this fixed for the next release.
Mike
- The topic ‘How to change the maximum and minimum values ​​in the legend result AQWA HD’ is closed to new replies.
