October 4, 2017 at 12:20 pm
nselvara
Ansys EmployeeThis can be done by modifying the key option. Use the following command to modify the key option: KEYMOD,ITYPE,KNUM,VALUE TYPE Element type number as defined on the ET command. KNUM Number of the KEYOPT to be defined (KEYOPT(KNUM)). VALUE Value of this KEYOPT. This is undocumented command. Sometime changing the key option abruptly can give wrong solutions, make sure that the results are correct
October 4, 2017 at 2:39 pm
vganore
Ansys EmployeeHow do you change the contact type from bonded to standard with change in load step?
- The topic ‘How to change the contact type from bonded to standard with change in load step?’ is closed to new replies.
