how to change the arrangement module
    • nhanani4
      I want to ask how can I want change the arrangement of module in ansys aqwa?
      I want to change structure ordering structure 1 from m2 into m1 and after that the ordering structure arranged like m1,m2 ,m3,m4,m5,m6,m7..
      How to do it? Can you me a suggestion.
      Should I draw again?
      What the different in group of structure i choose none or all?
      My simulation is about multi module floating structure.
      If I select none in interaction group 1, the simulation can be run  in hydrodynamic time response.
       If I select all in interaction group 1, the simulation cannot be run in hydrodynamic time response.
      In my simulation, multi module what should choose none or select all module?
    • Ingrid M
      It seems like a similar question was asked on this thread with a potential solution:
      /forum/forums/topic/ansys-aqwa-error-structure-move-to-far/
      Ingrid
  • The topic ‘how to change the arrangement module’ is closed to new replies.
