August 3, 2020 at 2:59 am
Keyur Kanade
Ansys EmployeeHow to change selection filter to select only edges in SpaceClaim? -
August 3, 2020 at 4:13 am
prajput
The selection filter is given at right hand side. In this filter please deselect 'Smart' option and then select only 'Edges' option to change selection filter to select edges only.Â
August 3, 2020 at 9:59 am
Keyur Kanade
Ansys EmployeeI have two edges at the same position. How can I select both of them? -
August 3, 2020 at 10:18 am
prajput
In SpaceClaim, you can select multiple entities. First select first entity using left mouse button (LMB). Then keep Ctrl key pressed and use mouse roll at that position. By using Ctrl key and LMB, select second edge.Â
August 3, 2020 at 10:31 am
Keyur Kanade
Ansys EmployeeHow do I select non transparant bodies only? -
August 3, 2020 at 10:54 am
prajput
The selection filter is given at right hand side. You can find Transparant Objects option in the same filter.Â
Viewing 5 reply threads
- The topic ‘How to change selection filter to select only edges in SpaceClaim?’ is closed to new replies.
Ansys Innovation Space
1414
1220
1118
1015
