October 7, 2021 at 5:03 am
venugopal4048
SubscriberDear all,
I want to change the element type and I want to assign the element different elements in ANSYS workbench. What is the procedure to change the element type?
Thank you very much,
Venugopalb
October 7, 2021 at 7:22 amRameez_ul_Haq
SubscriberRight click Mesh, select Method, and then select the type of element you want to use.
October 7, 2021 at 7:42 amvenugopal4048
SubscriberThank you for your response.
However, In general, it is okay. I want to choose specific elements (such as SHELL181, SOLID186,...). In this case, what is the procedure to assign a particular element?
regards
Venugopalb
October 7, 2021 at 8:06 amRameez_ul_Haq
Subscriberyou wrote ANSYS Workbench so I thought you are referring to assigning the element types by mouse clicks. But manually inputting the element type I guess will require an APDL command but I don't use it so I am not aware.
October 7, 2021 at 8:36 amvenugopal4048
SubscriberThank you
October 7, 2021 at 7:27 pmmrife
Ansys EmployeeWB Mechanical decides on the specific element type to write to the input file based on the shape & order of the mesh, along with the types of loading and boundary conditions. Normally there are not multiple element types that meet the specific criteria. So can I ask why you want to change the element type?
For example some of the much older, original element types still exist in the Mechanical APDL solver like Beam4 and Shell63. However they require real constant data instead of section data. So if you manually change say a Beam188 model to Beam4 the solver will throw an error, as there is no real constant data defined.
If you can explain why you need to change them I'll probably have a much better answer.
Mike
October 8, 2021 at 4:51 amvenugopal4048
SubscriberThank you very much for your response.
Actually, I am working on composites shell buckling. By default, ANSYS WB assigns the SHELL181 element for the structure. However, another shell element SHELL281 is also available and a Solid element, SOLID86 also available. So, I want to compare the accuracy and computational time of the analysis. So, that I need to assign various elements.
regards Venugopalb
October 8, 2021 at 6:39 amErKo
Shell281 you can simply get without any apdl command snippets, and just by setting in the mesh details, defaults, element order, and set it to quadratic.
The other option for solid86 one puts a command snippet under the body et,typeids(1),86
or
et,matid,86
Which changes it to solid86.
There are many links on this see:
/forum/discussion/2046/check-element-type
All the best
Erik
October 8, 2021 at 7:48 amvenugopal4048
October 13, 2021 at 2:14 pmOctober 14, 2021 at 5:01 amvenugopal4048
Subscriber.
Yes. It is SOLID186 element
Thank you
regards
Venugopalb
October 14, 2021 at 6:03 amErKo
Ansys EmployeeHI
Solid186 you can simply get without any apdl command snippets, and just by setting in the mesh details, defaults, element order, and set it to quadratic.
It is also the default element used by the mesher (if we do not change anything here and leave it to program default) for 3D solid parts.
So the command snippet I show say: et,matid,beam4 - in this case to change a beam188 element which is the default for line bodies, to a legacy beam4 element - so no need to use snippets on the elements that we already get by default (solid186) or by changing the element order setting (mentioned for getting shell281 elements).
All the best
Erik
October 14, 2021 at 10:14 amvenugopal4048
SubscriberThank you sir
January 23, 2023 at 7:39 amnagarajan.rajendran
SubscriberHi,
Check the ds.dat file and find for "ET, " and verify the no. of element types the model/region has been assigned. For the element type to be change, please use the following snippet;
*do,i,1,14
*do,j,15,28
et,j,223
esel,,type,,i
emodif,all,type,j
keyo,j,1,11 Â Â ! Â structural-thermal
keyo,j,2,0 Â Â Â ! Strong coupling
keyo,j,9,1 Â Â Â ! Thermoelastic damping suppressed
keyo,j,3,1 Â Â Â Â Â Â Â Â ! Axisymmetric
*ENDDO
*ENDDO
alls
etdele,1,14
allsIn the above example of the snippet, I am trying to change the element type " Plane 293" to "Plane 223". Default element type was Plane 293 was assigned to "1 to 14" element type no., I try to reassign it to "15 to 28" element type no. Prior to that, define the element type with Plane 223. Don't forget to set the Keypoint option relevant to the new element type...thanks
Regards
Nagarajan
Viewing 13 reply threads- The topic ‘How to change element type in ANSYS workbench?’ is closed to new replies.
4607
1515
1386
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
