January 17, 2024 at 3:30 pm
Dato
SubscriberHello,
I'm a fresher using Fluent Meshing. After generating volume mesh, the console has reported default quality-orthogonality. Now I want to change this metrics to others but I can't make it. Is it possible?
Besides, in "improve the vollume quality" task, the input value is also target limit orthogonality. Can it be changed? I have an question: In Fluent Meshing, how "improve the volume quality" works and will it impact other mesh criteria?
regards.
January 17, 2024 at 4:59 pm
Federico
Ansys EmployeeHello Lee,Â
In the Generate the Volume Mesh task, in Advanced Options, you have the option to choose between different mesh quality controls. 3.15. Generating the Volume Mesh (ansys.com)
The Improve the Mesh task will use a combination of the methods described here: 5.1. Improving the Mesh (ansys.com), in a way that drives the Volume Mesh quality towards the established target.
January 18, 2024 at 7:48 am
Dato
SubscriberOh, I see it. Thanks.
- The topic ‘How to change default element quality in Fluent Meshing?’ is closed to new replies.
