March 5, 2019 at 3:11 pm
Adisa
SubscriberHi,
Does anyone know how to change coordinate system in translational-joints.
In the reFerence coordinate system as default is used Reference Coordinate system, it is the input coord. system. I want to use stops in x direction but for another coord. system.
 Default:                   Needed coord.system as reference:
Thanks all.
March 5, 2019 at 3:41 pm
peteroznewman
SubscriberExpand the + sign under the Joint, in the Principal Axis category, set the Axis to X and on the Geometry, Click to Change and select some geometry that point in the desired direction.
If you don't have Geometry to use, then use the Coordinate System toolbar and click RZ and type in the rotation angle.
Then you will have this:
If this answers your question, please mark it with Is Solution to close the discussion or ask a followup question.
March 5, 2019 at 8:20 pm
Adisa
SubscriberThanks, it is what I need.
July 12, 2023 at 6:44 am
mert.dedebeyoglu
SubscriberCan we use existing coordinate system as a joint coordinate? I cannot find how to do that.
- The topic ‘How to change coordinate system in translational-joints’ is closed to new replies.
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
