how to change a piece from 3D to 2D
    • thabtisalma
      i have a piece in 3D and i want to convert it to 2D on ansys is't possible ??
      Create a surface in the XY plane if you want to do a 2D analysis.
      You can also use a surface in any plane in a 3D analysis and use a thickness property in the analysis.
      If you reply with a snapshot of your 3D piece and how you want to support and load it, I can give more advice.
      Joordr, please create a New Discussion in Structural Mechanics with this question (and delete your post from this discussion).
  • The topic ‘how to change a piece from 3D to 2D’ is closed to new replies.
