February 6, 2022 at 12:58 pm
Md_Salem
SubscriberI used to do harmonic analysis to free PZT PWAS in APDL in order to get electromechanical impedance spectrum VS frequency , as next sequence:
1- define the element and piezo-material structural parameters , coupled parameters and electric permittivity
2- modeling and meshing the free PWAS
3-select the upper surface nodes
4- create component for the top surface:
CM,TOP,NODE
5- couple the VOLT DOF for the top surface as set '1'
CP,1,VOLT,ALL
6- get node 'N1' on the upper electrode:
*GET,N1,NODE,,NUM,MIN
7- do the same for the lower surface ( BOTTOM,2,N2)
8- apply VOLT loads on the upper and lower surfaces :
D,TOP,VOLT,1
D,BOTTOM,VOLT,0
9- define the frequency range (start - end) and so frequency steps
10 - do the analysis
11- extract the charge on electrode and do external math to convert it to current then impedance and get the spectrum .
the output is 100% experimentally verified.
my question is how to carry out this procedure down from step number 4 for free PWAS ? , and if it is possible to get the impedance calculated directly in workbench 21R2 ?
February 7, 2022 at 6:11 pmAshish Khemka
Forum ModeratorFebruary 8, 2022 at 9:43 amMd_Salem
appreciated for your help, but unfortunately the attached video shows the steps that I have already stated for simulation of PZT in APDL. I need to learn how to do it in ANSYS 21R2 WORKBENCH
Regards MD Salem
Viewing 2 reply threads- The topic ‘how to carry out harmonic analysis to free piezoelectric PWAS in workbench ?’ is closed to new replies.
3572
1188
1076
1063
952
