September 6, 2020 at 2:12 pm
MTayyab
Subscriberhi, ni am studying vertical axis wind turbine. I am trying to do an analysis to find out that at a specific wind speed (input) what will be the turbine rpm?ni have already done the study by giving the turbine rotational speed (rad/s) using the sliding mesh technique.nWhat i want to do is that the turbine should rotate on it's own due to wind load not because of a pre set condition.....nthanks!n -
September 7, 2020 at 2:24 pm
Forum ModeratorThat will be a function of the force on the blade(s) and resistance to motion due to flow & whatever the VAWT is attached to. Should be possible with a user function. n -
September 7, 2020 at 6:17 pm
Amine Ben Hadj Ali
Ansys EmployeeRigid body motion look in the CFX documentation n
- The topic ‘how to Calculate turbine rpm using ansys cfx?’ is closed to new replies.
Ansys Innovation Space
1414
1193
1100
1015
