How to calculate the zero thickness wall’ temperature?
    • pssjn
      Is it possible to calculate the wall temperature of 'zero thickness wall'? What is the best way to calculate natural air ventilation rate of a room in fluent?
      Best regards,
      Farhan
    • DrAmine
      Ventilation rate is the amount of air feed into /exiting the system divided by the volume of the room.
      And yes: Wall temperature can be post-processed for zero-thickness (default walls) in Fluent/CFD-Post.
    • pssjn
      Thanks. Could you please explain more about the zero thickness wall.
      Regards.
    • DrAmine
      Please have a look in the Fluent User's Guide: that is non-resolved wall with zero thickness say with zero resistance between its sides.. That is the default wall boundary condition in Fluent.
  • The topic ‘How to calculate the zero thickness wall’ temperature?’ is closed to new replies.
