October 16, 2024 at 3:39 pm
sornakumarrr
SubscriberHello I am learning how to use HFSS and am trying to replicate a metasurface. The metasurface is designed for circular polarization so I am using floquet ports to simulate a unit cell. I turned on TE mode and also TM mode but with 90 degree phase in edit sources so that it would create a circularly polarized mode. Where I am having trouble is how to read the s parameters for the circularly polarized mode? -
October 16, 2024 at 4:31 pm
Guilin Sun
Ansys EmployeeHi This is Photonics forum. Please submit your question to HFSS forum https://innovationspace.ansys.com/forum/forums/topic-tag/ansys-hfss/
In Lumerical FDTD, once you use ports you can automatically get S parameters. However currently the port does not use circular polarization source. You will need to do two simulaitons and combine the S results, if you use Lumerical FDTD. Ports are mainly used for waveguide modes.
October 16, 2024 at 6:16 pm
sornakumarrr
SubscriberThank you, i will follow your instruction
October 17, 2024 at 6:30 am
sornakumarrr
SubscriberCould you please explain how to combine the S11 parameters of TE and TM modes to determine the CP S11 parameter?
October 17, 2024 at 3:17 pm
Guilin Sun
Ansys EmployeeÂ
This is more of math/physics questions. Suppose you use Ex,Ey as sources respectively, you get Sx and Sy. If you use Ex+jEy as the circular polarization, the result will be Sx+jSy. Please verify.
You may need to normalize the result with sqrt(2)/2.
October 19, 2024 at 3:18 am
sornakumarrr
SubscriberThanks for the suggestion
5719
