How to calculate local volumetric flow rate over some portion of a section .
    • Sliceee123
      Suppose for a pipe flow problem the cross sections are circle , so I can find velocity contour of circular shape , if I want to calculate the average velocity and volume flow rate over some portion of the circle how can I do that in Ansys fluent (post processing) ?
    • Kishan Konannavar
      Hello
      Maybe using the Surface Integrals option in the reports task page could help. You could refer the following link.
      43.20.4. Surface Integrals Dialog Box (ansys.com)
      Regards
      Kishan
  • The topic ‘How to calculate local volumetric flow rate over some portion of a section .’ is closed to new replies.
