August 3, 2020 at 3:01 am
Keyur Kanade
Ansys EmployeeHow to calculate individual and total inflation layer thickness? -
August 3, 2020 at 4:16 am
prajput
Given First layer Thickness, Growth Rate and Number of Layers, individual layer thickness and total thickness can be calculated as follows for inflation layers Nth Layer Thickness = (First Layer Thickness)* (g)^(N-1). Total thickness = (First layer Thickness)*[1-g^(N+1)]/(1-g) where g is the growth rate.
August 3, 2020 at 10:01 am
Keyur Kanade
Ansys EmployeeWhat are inflation layer options available in meshing? -
August 3, 2020 at 10:21 am
prajput
In meshing, you can use Total Thickness, Smooth Transition, First Aspect Ratio and Last Aspect Ratio methods. For more information about each method, please check help manual link as follows. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v194/wb_msh/msh_Inflation_Opt_Global.html?q=Total%20Thickness%20Inflation
August 3, 2020 at 10:33 am
Keyur Kanade
Ansys EmployeeThank you, that answers my question. I will go ahead with Last Aspect Ratio.Â
Viewing 4 reply threads
- The topic ‘How to calculate individual and total inflation layer thickness?’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
